Question Moo/Kunena conflict
- Phill Luckhurst
I know this is more of a problem with the Joomla template but if anyone has any ideas on how to fix this it would be great.
Here is where you can see the problem.
test.windsurf.me.uk
Take a look at the dropdown menus and the work fine but go to the forum link in the menu bar to the kunena page an you will see the dropdown give up the ghost.
The problem appears to be coming from the jquery-1.3.2.min.js file, I think
Look if your template load the jquery library and prevent kunena to loard jquery library too by commenting in the file components\com_kunena\class.kunena.php the lines 284 to 291 :
- Phill Luckhurst
- woonydanny
- Elite Member
- Thank you received: 22
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
You lost anything, because the jquery is loaded by your joomla! template.Thanks for the quick response and indeed it works. Out of interest what functions are lost by disabling that script?
peetree21 wrote:
Like that the conflict are reduced because each components doesn't need to load their own MooTools library. Mootools 1.2 will be shiped in the future version of J! 1.5.I believe that Kunena 1.6 has dropped jquery and uses mootools 1.2 which will ship native in joomla 1.6
