Question Avatar Image Help
16 years 9 months ago #38926 by sapperk
Avatar Image Help was created by sapperk
The only Avatar that display in my forums is the one who started the subject. How can I enable it to display all the avatars of the people who have replied as well. I looked through the config and could not figure it out. Any thoughts?
16 years 9 months ago - 16 years 9 months ago #38944 by xillibit
Replied by xillibit on topic Re:Avatar Image Help
What kunena version do you using ? What kunena template do you have ?
The avatars are present in joomla\images\fbfiles\avatar with the right permissions ?
And do you have a link to your site ?
Last edit: 16 years 9 months ago by xillibit.
16 years 9 months ago #39113 by sapperk
16 years 9 months ago #39121 by xillibit
Can you provide please a test account to access to your forum ?
16 years 9 months ago - 16 years 9 months ago #39201 by sapperk
My Site Link
As you can see I think I have an issue. The problem is the avatar is only showing up for whoever made the first post of each page. Eveything under the first post doesnt.
What or how do i make it so every reply also shows the avatar? I have tried to mess with all the option in configuration but cant seem to get it to work. Please help me. :)
If you would like to check it out further you can log into my site using:
Username: test
Password: testtest
Installed version: Kunena 1.5.8
Template: Default_ex
Last edit: 16 years 9 months ago by sapperk.
16 years 9 months ago - 16 years 9 months ago #39204 by sozzled
Replied by sozzled on topic Re:Avatar Not Showing Up
Thank you for posting a link to your website. It appears you are using K 1.5.8 or K 1.5.9 (you will have to tell us which one). It should not matter if you are running J! 1.5 in "legacy" mode although it would be wise to eliminate any Joomla 1.0 extensions from your site. B)
I am not familiar with the Kunena template you are using. As you know, There is only one endorsed and supported Kunena template ... default_ex . What happens if you use the default_ex template? Does this fix your avatar issue?
Last edit: 16 years 9 months ago by sozzled.
