Question Avatar Image Help
What kunena version do you using ? What kunena template do you have ?
The avatars are present in joomla\images\fbfiles\avatar with the right permissions ?
And do you have a link to your site ?
My Site Link
As you can see I think I have an issue. The problem is the avatar is only showing up for whoever made the first post of each page. Eveything under the first post doesnt.
What or how do i make it so every reply also shows the avatar? I have tried to mess with all the option in configuration but cant seem to get it to work. Please help me.
If you would like to check it out further you can log into my site using:
Username: test
Password: testtest
Installed version: Kunena 1.5.8
Template: Default_ex
I am not familiar with the Kunena template you are using. As you know, There is only one endorsed and supported Kunena template ... default_ex . What happens if you use the default_ex template? Does this fix your avatar issue?
