Please read
Question Header Problem When Viewing a Thread
16 years 4 months ago - 16 years 4 months ago #35350
by roykyle
Header Problem When Viewing a Thread was created by roykyle
Hello guys, I've got one problem with Kunena wherein the header text do not display properly when viewing a thread. The header text is being cut. You can see it on the image below where the arrow is pointing. The text ESLCorner Forum, Categories and My Profile are cut. What should I do with this? Please help me. Thank you in advance.
Last edit: 16 years 4 months ago by roykyle.
16 years 4 months ago #35371
by Matias
Replied by Matias on topic Re: Header Problem When Viewing a Thread
Please change your template to default_ex. Default_gray has already been removed as it was not kept up to date and it was broken.
Are you having the same issue with default_ex?
16 years 4 months ago - 16 years 4 months ago #35385
by roykyle
Replied by roykyle on topic Re: Header Problem When Viewing a Thread
Hello there, thanks for your quick response. Yah, I get the same issue with default_ex template and the other available templates. But default_ex is a little bit better when you see the image below with default_ex template. This problem only arises when a user post a message and where the browser automatically redirects you to the page where you post the message. But when I use other templates like default_gray, default_green and default red, it arises when viewing the thread and posting thread.
Thanks again.
Thanks again.
- rinuccio sp
- Premium Member
- Thank you received: 4
16 years 4 months ago #35413
by rinuccio sp
Replied by rinuccio sp on topic Re: Header Problem When Viewing a Thread
This problem occurs with all templates of YOOtheme
16 years 4 months ago #35479
by Matias
So Yootheme templates somehow break Kunena CSS.
Easiest way to fix this is to install FireBug into FireFox and find the problematic css code by using it. Then just edit it in FireBug trying to fix it and apply the change into our CSS file (you can edit it from the backend).
If you find out the conflicting rule and report it (or provide url so someone can look at it), we may have changes to get it into the next release.
16 years 4 months ago #35517
by roykyle
Thanks for the help. I'll try to work it out which one I should edit. Have a great day!
Time to create page: 0.211 seconds
