Question How to set Kunema width?
I'm trying to set Kunema to fit middle+right columns.
I'm not sure if it is a Kunema set or a template problem.
If you take a look to my site, www.nitromodelismo.com.br/fireboard-forum.html
you will see, by the border, that the template is using all the middle + right area, but Kunema is not using it.
My template.css file has this config: #leftwrapleftonly{width:100%;}
If there is some good soul to help me on it, I will appreciate
I'm attaching my template.css file.
try this
template.css line 323
#mainbody {
padding:0;
width:100%;
Regards
It worked perfect!!!
Thank you very much!!!
Ciro.
