Question Kunena and Joomla - BB not using Joomla CSS
16 years 7 months ago #29175 by misterchris
Hi all
bit new to this, so please be gentle with me! :)
I installed Joomla, and stumbled across Kunena which I think looks amazing
Managed to upload it and link it to a menu item, but the problem I am getting is that when I click the link, it opens without any formatting - I think it is not using the CSS styles from Joomla
I am a bit of a noob when it comes to this, any advice would be appreciated - I am sure I will be OK configuring the board itself, I would just ideally like it to open within an existing frame on the Joomla template
If I have not explained myself properly feel free to ask :)
Thanks in advance
Chris
16 years 7 months ago #29189 by @quila
Hi misterchris,
try changing the Joomla template to see if the problem is there and use Kunena default_ex template.
Regards
16 years 7 months ago #29284 by rekamorvay
I'm having the exact same problem. I installed Kunena, the backend looks fine, but when I click on any links from my Joomla frontpage to go to the frontend of Kunena, all the formatting is broken. I've tried setting it to use the Joomla template formatting, no change, I've tried setting it to use the Kunena templates, no change.
Any ideas? You can see what I'm talking about here www.budapest-moms.com/index.php/forum
Thanks a lot! :)
Réka
16 years 7 months ago #29331 by nzjacob
This works fine - www.budapest-moms.com/index.php?option=com_kunena&Itemid=55
Are you using a 3rd part SEF product ?
Time to create page: 0.235 seconds
