Question Error in Color Palette
17 years 3 months ago #25827 by sozzled
Replied by sozzled on topic Re:Error in Color Palette
If I understand your situation correctly, the problem you have occurs on a website created on your personal computer. Is that correct?
This makes it virtually impossible for someone else to investigate what is causing the malfunctioning Javascript.
What system are you using (e.g. XAMPP) to host your website? I am using XAMPP (version 1.7.1 for Windows) and I don't see the problem that you're having. As Lintzy and xillibit have suggested earlier, your problem bears all the trademarks of a conflicting Javascript routine involved in another Joomla extension that you have installed.
Another alternative is to create a fresh Joomla website, install Kunena and nothing else, and see if the problem occurs then. If there is no problem then you know it's not Kunena that's the cause of the fault. :)
17 years 3 months ago #26124 by lamblety
Replied by lamblety on topic Re:Error in Color Palette
Thanks.
I've found the problem but i don't know hou to fix this... see
The error is in this template
www.kunena.com/forum/136-templates-and-d...kunena-154-templates
"default_ex_black"
Can someone teel me how I install a template in Kunena, to see if i'm doing right???
Or someone know how i fiz this problem???
It will help me a lot.
I'm waiting for a reply.
17 years 3 months ago - 17 years 3 months ago #26142 by sozzled
Arrrgghhhh! You mean you hadn't tested to see if the problem could be reproduced using the default_ex template? :side:
OK. Simple solution. Read Configuration Tips in the Wiki.
And, for future reference, please read There is only one endorsed and supported Kunena template . ;)
I hope xillibit reads this message; maybe then he'll understand why I'm making an issue out of the defective template issue and why it's necessary for clear, unambiguous advice.
Last edit: 17 years 3 months ago by sozzled.
17 years 3 months ago #26150 by lamblety
Thanks for tghe answer.
But i wanna use this template "default_ex_black"...
this is perfect for my website...
Someone know where i found the code of the color pallet?
Best Regards.
17 years 3 months ago #26295 by lamblety
I've found the error!!!!!!!!!!!!!!
Line 56:
" background: #222222 url(images/bg2.png);"
to
" background: #222222;"
Thanks again for the help......=)
17 years 3 months ago #26543 by kylereese
Replied by kylereese on topic Re:Error in Color Palette
Yes, it works great! Fine!
I´ve got another Problem... When adjusting the fontsize - it only works for one time with the same size - or am I wrong? :unsure:
Time to create page: 0.150 seconds
