Question Avatar upload problem >> JFile::copy: Cannot find or read file: ''
16 years 8 months ago #38688 by tarabantika
My site is online, everything works fine, except Kunena 1.5.8 refuses to upload any avatars. While it was running on the localhost, everything worked also fine including avatar upload.
I get this error message after pressing upload:
My permissions for ALL joomla files and folders are set to 777, and Joomla! system information in the backend says that every directory is writable, every directory comment is green "writable".
What's wrong? Can someone please help me, it's getting me nuts.. :(
16 years 8 months ago #38719 by tarabantika
Thank you very much for the reply! Yes, it did work :)! But, now Kenuna does not resize the avatars automatically .. :(
User of the website need to resize them first manually to 250x250 (my own settings) before uploading them..
Do you know any other solution?
Thanks again!
