Question Avatar upload problem >> JFile::copy: Cannot find or read file: ''
- tarabantika
16 years 3 months ago #38688
by tarabantika
My site is online, everything works fine, except Kunena 1.5.8 refuses to upload any avatars. While it was running on the localhost, everything worked also fine including avatar upload.
I get this error message after pressing upload:
My permissions for ALL joomla files and folders are set to 777, and Joomla! system information in the backend says that every directory is writable, every directory comment is green "writable".
What's wrong? Can someone please help me, it's getting me nuts..
16 years 3 months ago #38691
Replied by sozzled on topic Re:Avatar upload problem >> JFile::copy: Cannot find or read file: ''
Try this idea:
Avatar Uploading doesn't work
. Please let us know if it works for you.
- tarabantika
16 years 3 months ago #38719
by tarabantika
Replied by tarabantika on topic Re:Avatar upload problem >> JFile::copy: Cannot find or read file: ''
Thank you very much for the reply! Yes, it did work
! But, now Kenuna does not resize the avatars automatically ..
User of the website need to resize them first manually to 250x250 (my own settings) before uploading them..
Do you know any other solution?
Thanks again!
Thanks again!
16 years 3 months ago #38732
Replied by sozzled on topic My avatar image is too large for my template
Known issue with K 1.5.9. See
1.5.9 - Known issues
Time to create page: 0.249 seconds
