Question Agora > Kunena - error in tables
16 years 1 month ago - 16 years 1 month ago #66213 by peterdyhr
I've tried the converter for converting Agora 3.0.137 to a new Kunena 1.5.12 installation.
I get all data except the messages itself. In all fora it counts the number of threads allrigt, but they are all empty.
This is the errormessage when I try to convert:
Fatal error: Uncaught exception 'Exception' with message 'KunenaConvertersModelKunenaConverters::_insertData failed. (Duplicate entry '1' for key 1 SQL=INSERT INTO jos_fb_categories (id,name,published,parent,ordering,pub_access,pub_recurse,admin_access,admin_recurse) VALUES ('1','Offentligt Forum','1','0','1','0','1','0','1'))' in /home/www/mysite.dk/administrator/components/com_kunenaconverters/models/kunenaconverters.php:367 Stack trace: #0 /home/www/mysite.dk/administrator/components/com_kunenaconverters/models/kunenaconverters.php(129): KunenaConvertersModelKunenaConverters->_insertData('fb_categories', Array) #1 /home/www/mysite.dk/administrator/components/com_kunenaconverters/models/kunenaconverters.php(35): KunenaConvertersModelKunenaConverters->_importAgoraForums() #2 /home/www/mysite.dk/administrator/components/com_kunenaconverters/controllers/kunenaconverters.php(37): KunenaConvertersModelKunenaConverters->agora() #3 /home/www/mysite.dk/libraries/joomla/application/co in /home/www/mysite.dk/administrator/components/com_kunenaconverters/models/kunenaconverters.php on line 367
Does anyone have a clue to help me?
Last edit: 16 years 1 month ago by peterdyhr.
16 years 1 month ago #66223 by snilloconator
What converter are you using? I just did this 2 days ago with great success.
16 years 1 month ago #66228 by Enes
I also use this extension to convert Agora > Kunena and it is done successfully. What convertor did you use?
16 years 1 month ago - 16 years 1 month ago #66275 by peterdyhr
Yes that's the one I used too.
I'm wondering if it could be because I have 2 parts of my forum, 1 for registrered users and 1 for members only.
I see all headlines for the threads in "Subject" and even read the popups, but all the threads themselves are not showing when you click them.
Members, Answers, subjects and sections are all there, but categories are not shown and the value in the backend is 0.
16 years 1 month ago #66329 by peterdyhr
I found the solution myself.
I had categories with the same name i both fora.
Once I renamed one of them, it converted everythig - even photos and pdf's.
Problem solved.
