Idea (solved) kun 1.5.11 upgrade to kun 1.5.12 didnt work
* It was not possible to copy the selected file.
* JInstaller::install: Failed to copy file: /home/tracinge/public_html/horses/tmp/install_4c1fefcce5fb3/CHANGELOG.php to /home/tracinge/public_html/horses/components/com_kunena/CHANGELOG.php
Backed up whole Joomla DB
Uninstall kun 1.5.11
Install kun 1.5.12
All files still on website server
Not sure where category/forum setup is stored
Not sure whether best to delete all files n then try re-install kun 1.5.12
Edit to add -
Edit 2 - deleted files on server, installed kun 1.5.12 just fine, now to go play with the new bits :woohoo:
Ignore me, I'm a dizzy blonde at times!
ah but are you a cute dizzy blonde? cause then i will forgive you
small n very cute with a nice bum
