Question email subscription kunena not work
I have just installed Kunena 1.5.11 and joomla 1.5.18
but I do not receive email subscription from kunena.
I receive email if I report to moderator, but not the subscription :S
In the Kunena configuration Allow subscription is set to Yes.
Can anyone help?
try and do a search first, there are plenty of threads on this issue.
regards Mikkel.
thanks for the answer
I have seached this forum and google, but I did not find anything to solve the problem.
By the way I am not in localhost and I have:
PHP: 5.2.9
MySQL: 5.0.90
- Are you sure that you subscribed to the specific topics that should have generated emails?
- Are you using the same email account as the one that you received your emailed "report to moderator" messages?
- Have you looked in your junk mail folder?
It's possible that your problems derive from something else on your website that you haven't told us about; it could be something that has its roots in another Joomla extension, for example. These are difficult questions to answer but, as I wrote elsewhere (two months ago):
I understand people's hesitation to use K 1.5.11 after the embarrassment of K 1.5.10. However, even though K 1.5.11 has been available to the public for the past 5 days, this version was subjected to exhaustive testing - we were exhausted from testing it :laugh: - for over a week before that. K 1.5.11 was implemented on this site and has been working here (especially in the e-mail department) for nearly two weeks.
I think that, after everything that has been written here, we can reasonably conclude that K 1.5.11 is inherently stable as far as email is concerned.
* Are you sure that you subscribed to the specific topics that should have generated emails?
* Are you using the same email account as the one that you received your emailed "report to moderator" messages?
* Have you looked in your junk mail folder?
The answer is yes for all the question.
I don't have any particular component installed on joomla
So.... the problem could be only related to my hosting service?
I will test to the site on a different hosting company... to see if it work.
Is there anything else that I can do?
