Important Help getting set up
16 years 5 months ago - 16 years 5 months ago #49675 by Sonic
Help getting set up was created by Sonic
Thanks so much for such a great forum for Joomla, I'm looking forward to getting it going.
On install of 1.5 I'm seeing this error.
Warning: require_once(/home/fligh10/public_html/joomla/components/com_mypms/class.mypms.php) [function.require-once]: failed to open stream: No such file or directory in /home/fligh10/public_html/joomla/components/com_kunena/kunena.php on line 197
Anything I can do to fix er up? Thanks in advance for any and all suggestions.
Last edit: 16 years 5 months ago by Sonic.
16 years 5 months ago #49677 by @quila
Replied by @quila on topic Re: Help getting set up
Hi Sonic,
You can not install Kunena or you have successful installed kunena and you see that warning?
If you have already installed kunena check in the configuration of kunena "Integration" -> "Private messaging component", You have selected messaging component which is not installed on your site.
Regards
16 years 5 months ago #49678 by Sonic
Replied by Sonic on topic Re: Help getting set up
That's exactly what it was...thanks so much for the very speedy and most helpful reply!
