Question Issue posting messages on site since site migration
16 years 6 months ago #47315 by andrewdna
Hi there,
I don't normally ask for help, so i do really need it this time around.
ummmm basically what appears to happen is when i log into forum,
when i got to post message, i get a save file for "index.php"
i have moved site from one host to another,
i am using PHP Version 5.2.10, mysql-server-5.0.77,
my site is www.indie-rocks.co.uk
everything else seems to work fine, any one got any ideas?
if i have missed anything else out, ask away and will give that info too.
thanks for your time!
16 years 6 months ago #47317 by andrewdna
i can reply to already existing posts, just unable to create new ones
16 years 6 months ago #47319 by Cerberus
What version of kunena do you have installed?
16 years 6 months ago #47327 by andrewdna
i am using
com_kunena_v1.5.11_stable_b1884_2010-04-04
16 years 6 months ago #47329 by Cerberus
i see you have a modified template please change your template back to default_ex and test again.
16 years 6 months ago #47621 by sozzled
G'day,
I had a look at the site. Although it may be true that the site is using K 1.5.11, the forum indicates otherwise.
I've seen this problem before and, if you re-install K 1.5.11 and use the default_ex template then your problems should disappear. ;)
