Question After phpbb > fb > kunena conversion... i need to have legacy on..???
16 years 6 months ago #46973 by gjhvs
Hello!
I have converted my phpbb3 forum to fireboard.
Deleted Fireboard and installed Kunena.
I do get Kunena working but ONLY if I turn on Legacy..
Is that normal? I thought Kunena worked fine under Native?
Did I forget something to do during the conversion?
16 years 6 months ago #46977 by xillibit
From what fireboard version do you have migrated ?
What Kunena version do you have isntalled ?
16 years 6 months ago #46979 by gjhvs
Kunena 1.5.11
Fireboard was version 1.0.4. ( docs.kunena.com/index.php/PHPBB3_to_Kunena ).
I did use an other converter than mentioned on this page (it wasn't working).
I converted te phpbb forum to fireboard.. and checken if everything was in place. It was..
What I didn't do was step 10 becuase everything was in place.... (10.Use the com_fbconverter to prepare the database, for the kunena installation, you can download it here : [2]. Now you can uninstall the com_converter by using the joomla! extensions manager.)
Could that be the problem?
16 years 6 months ago - 16 years 6 months ago #46982 by xillibit
The com_fbconverter is needed to save the configuration file into the database, so this step can be skipped if you don't want to keep configuration settings.
If you disable the mode legacy, what's happen exactly ?
Last edit: 16 years 6 months ago by xillibit.
16 years 6 months ago #46983 by gjhvs
I can't reacht the forum. I get this message:
Direct Access to this location is not allowed.
16 years 6 months ago #46984 by xillibit
At the top of your language file (administrator/components/com_kunena/language/kunena.yourlanguage.php) , do you have this :
defined ( '_JEXEC' ) or die ();
