Everything works perfectly until you click the back button when you're in the registration form, then you get the:
Warning: include_once(C:\wamp\www\joomla\components\com_kunena\lib\kunena.debug.php) [function.include-once]: failed to open stream: No such file or directory in C:\wamp\www\joomla\modules\mod_kunenalatest\helper.php on line 5
Warning: include_once() [function.include]: Failed opening 'C:\wamp\www\joomla\components\com_kunena\lib\kunena.debug.php' for inclusion (include_path='.;C:\php5\pear') in C:\wamp\www\joomla\modules\mod_kunenalatest\helper.php on line 5
Warning: require_once(C:\wamp\www\joomla\components\com_kunena\lib\kunena.config.class.php) [function.require-once]: failed to open stream: No such file or directory in C:\wamp\www\joomla\modules\mod_kunenalatest\helper.php on line 6
Fatal error: require_once() [function.require]: Failed opening required 'C:\wamp\www\joomla\components\com_kunena\lib\kunena.config.class.php' (include_path='.;C:\php5\pear') in C:\wamp\www\joomla\modules\mod_kunenalatest\helper.php on line 6
