Question Problem updating from 1.5.9 to 1.5.11
Please help i can not turn my forum back online.
Kunena Configuration » Basics » Forum Offline = Yes
Then you upgraded to K 1.5.11. Then you went back to your Kunena control panel to re-enable your forum, i.e., to change the Configuration settings as follows:
Kunena Configuration » Basics » Forum Offline = No
Then, when you press Save, you got the error messages. Is that correct? Don't worry, we'll get your forum running again.
The second approach is to look at what might have gone wrong. I suspect that your installation procedure didn't complete successfully. Did you, by any chance, make a backup of your website just before you installed K 1.5.11?
We've had one or two questions asked recently about problems with "incomplete" Kunena installations, more questions than I've seen asked in relation to previous versions of Kunena, and I'm wondering whether there is any commonality between them. Which installation kit did you use? ZIP or TAR? I prefer to use ZIP kits - I've never had a problem with them. I'll get back to you as soon as I find what DB table and field is responsible for disabling your Kunena forum.
