Question Upgrade Issues from Fireboard
Are you getting a specific "upload error" (your words, not mine) message?
-1 - An error has occurred.
It was not possible to copy the selected file.
Call stack
# Function Location
1 JAdministrator->dispatch() /home/wolstant/public_html/administrator/index.php:67
2 JComponentHelper->renderComponent() /home/wolstant/public_html/administrator/includes/application.php:130
3 require_once() /home/wolstant/public_html/libraries/joomla/application/component/helper.php:162
4 JController->execute() /home/wolstant/public_html/administrator/components/com_installer/admin.installer.php:44
5 InstallerController->doInstall() /home/wolstant/public_html/libraries/joomla/application/component/controller.php:236
6 InstallerModelInstall->install() /home/wolstant/public_html/administrator/components/com_installer/controller.php:71
7 JInstaller->install() /home/wolstant/public_html/administrator/components/com_installer/models/install.php:86
8 JInstallerComponent->install() /home/wolstant/public_html/libraries/joomla/installer/installer.php:333
9 com_install() /home/wolstant/public_html/libraries/joomla/installer/adapters/component.php:270
10 JFolder::copy() /home/wolstant/public_html/administrator/components/com_kunena/install/kunena.install.php:149
11 JFolder::copy() /home/wolstant/public_html/libraries/joomla/filesystem/folder.php:111
12 JError::raiseError() /home/wolstant/public_html/libraries/joomla/filesystem/folder.php:120
13 JError::raise() /home/wolstant/public_html/libraries/joomla/error/error.php:173
14 JException->__construct() /home/wolstant/public_html/libraries/joomla/error/error.php:138
Major factor (as far as Kunena is concerned). This site and the documentation Wiki are littered with innumerable warnings about what yo must do as far as Kunena and Community Builder are concerned.I think I may have discovered the issue! I am usin CB version 1.1. Could it be a factor?
Sounds like a folder permissions problem. Check that your site conforms to Joomla standard folder permissions settings at the very minimum.I put the site on debug and I get:
