Question DB function failed, Installation error
16 years 8 months ago #42851 by herinoer
when i try to install kunena 1.5.9, I take this error:
* Component Install: DB function failed with error number 2006
MySQL server has gone away SQL=INSERT INTO jos_components VALUES( 0, 'Kunena Forum', 'option=com_kunena', 0, 0, 'option=com_kunena', 'Kunena Forum', 'com_kunena', 0, 'js/ThemeOffice/component.png', 0, '', 1 )
SQL =
* It was not possible to copy the selected file.
* JInstaller::install: Failed to copy file: /home/amax/public_html/forum/tmp/install_4ba2f603b54d0/manifest.xml to /home/amax/public_html/forum/administrator/components/com_kunena/manifest.xml
* Component Install: Could not copy setup file
* Error Loading ModulesMySQL server has gone away SQL=SELECT id, title, module, position, content, showtitle, control, params FROM jos_modules AS m LEFT JOIN jos_modules_menu AS mm ON mm.moduleid = m.id WHERE m.published = 1 AND m.access <= 2 AND m.client_id = 1 ORDER BY position, ordering
what should i do?
I have:
Mysql : 5.0.89 community
PHP 5.2.8
I've tried to install with .zip, tar etc format..
I've change the file permision to 777 /component, tmp/ images
Thanx
16 years 8 months ago #42894 by xillibit
Your MySQL server has gone away, try to re-install kunena by putting kunena in /tmp and launch the install from this directory.
16 years 8 months ago #42981 by Matias
You should increase MySQL timeout to around 180 seconds and try again. Copying files takes a long time and MySQL should be nice and keep waiting during that time.
16 years 8 months ago #43153 by herinoer
I didnot find the way to increase mysql timeout in this forum. Can you direct me about it?
16 years 8 months ago #43175 by Matias
It has nothing to do with Joomla or Kunena. It's a server setting. Please ask it from your service provider.
Time to create page: 0.235 seconds
