Question Upgrade from 1.5.8 went wrong
16 years 8 months ago - 16 years 8 months ago #42789 by robject
I upgraded my joomla 1.5.15 site from Kunena 1.5.8 to 1.5.9.
The upgrade went successfully (at least it reported no errors). However I am unable to access the Kunena backend:
Parse error: syntax error, unexpected $end in /home/sephernl/public_html/administrator/components/com_kunena/toolbar.kunena.php on line 92
I do not have JoomSuitDefender, which seems to have caused similar issues in the past, as I found on the forum.
The site url is www.sepher.nl in case you want to check.
Last edit: 16 years 8 months ago by robject.
16 years 8 months ago #42793 by xillibit
re-upload the file /home/sephernl/public_html/administrator/components/com_kunena/toolbar.kunena.php, because some times the joomla! installer corrupts the files.
16 years 8 months ago #42797 by robject
ok, I did that manually (unzipped the kunena installer and ftp-ed the file to the directory). Now things seem to work fine, thank you.
