Question Problem with Installation
16 years 8 months ago #42367 by bigmike0601
I intstalled joomla 1.5 successfully then tried to install Kunena 1.5.9 and got the following error.
"The server encountered an unexpected condition which prevented it from fulfilling the request. The script had an error or it did not produce any output. If there was an error, you should be able to see it in the error log."
16 years 8 months ago #42369 by sozzled
Although the information at Technical Requirements (in the Wiki) is a little out-of-date, have you looked at it in terms of helping to diagnose what has occurred in your case? Pay particular attention to what version of Joomla you are using, PHP, MySQL, webserver software, directory permissions, server execution time-outs, etc.
If you could provide more information on your current hosting platform, any specific error messages (e.g. have you enabled Joomla debug mode?), this would also help.
16 years 8 months ago #42370 by bigmike0601
I appologize for not knowing a whole lot about this. I did read the tech section, but im very new to all of this.
I'm using Joomla version 1.5.15 and debug system and language are set to default 'no'. I will have to find out other info as I really do not know.
16 years 8 months ago #42371 by bigmike0601
Type Debian
MySQL Version
5.0.77
Perl Version
Perl 5.8.8
PHP Version
PHP 5.2.2
16 years 8 months ago #42372 by bigmike0601
I turned debugs to on and it intalled fine. Do I turn them off now?
16 years 8 months ago #42373 by xillibit
Normally when you enable the debug mode during kunena isntallion, this causing issues.
Do you have the message : "installation sucessful" ?
