- Thank you received: 2
Question Problem with Installation
- bigmike0601
- Senior Member
"The server encountered an unexpected condition which prevented it from fulfilling the request. The script had an error or it did not produce any output. If there was an error, you should be able to see it in the error log."
If you could provide more information on your current hosting platform, any specific error messages (e.g. have you enabled Joomla debug mode?), this would also help.
- bigmike0601
- Senior Member
I'm using Joomla version 1.5.15 and debug system and language are set to default 'no'. I will have to find out other info as I really do not know.
- bigmike0601
- Senior Member
MySQL Version
5.0.77
Perl Version
Perl 5.8.8
PHP Version
PHP 5.2.2
- bigmike0601
- Senior Member
Normally when you enable the debug mode during kunena isntallion, this causing issues.
Do you have the message : "installation sucessful" ?
