Question Upgrade Process Fatal Error "Class fx_Upgrade"
16 years 8 months ago - 16 years 8 months ago #40841 by masteryoda1047
just tried to update kunena to the current branch 1.0.11 and got some fatal error message:
Warning: include_once(/var/www/webdav/intranet/joomla/administrator/components/com_kunena/lib/fx.upgrade.class.php) [function.include-once]: failed to open stream: No such file or directory in /var/www/webdav/intranet/joomla/administrator/components/com_kunena/install/kunena.install.php on line 43
Warning: include_once() [function.include]: Failed opening '/var/www/webdav/intranet/joomla/administrator/components/com_kunena/lib/fx.upgrade.class.php' for inclusion (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/webdav/intranet/joomla/administrator/components/com_kunena/install/kunena.install.php on line 43
Fatal error: Class 'fx_Upgrade' not found in /var/www/webdav/intranet/joomla/administrator/components/com_kunena/install/kunena.install.php on line 75
The board seems to be working. Do i have to be worried?
Edit: the file fx.upgrade.class.php is really missing in above path
Edit2: i reinstalled Version 1.0.8 and it went smooth
regards
Last edit: 16 years 8 months ago by masteryoda1047.
16 years 8 months ago #40842 by masteryoda1047
i've done a chmod 777 on the administrator/components/com_kunena path and now it works as expected!
cya
Time to create page: 0.091 seconds
