Important Installation Error
16 years 9 months ago #38940 by jjpedersen
Each time I attempt to install Kunena 1.5.9 on a Joomla 1.5.15 Stable, I get the following error.
* It was not possible to copy the selected file. * JInstaller::install: Failed to copy file: /xxxxxxxxxxxx/tmp/install_4b684d2a94f08/CHANGELOG.php to xxxxxxxx/components/com_kunena/CHANGELOG.php
When I check my file permission under SYSTEM INFO > Directory Permissions, I have all "Writable" all the way down.
I checked to see if I could install other components and was able to quickly install Community Builder and all the different mods and plgs.
I also looked at the file structure for my Joomla, and the install did copy the CHANGELOG.php to the components directory, so I'm not sure where to go from here.
Any suggestions?
16 years 9 months ago #38942 by xillibit
Replied by xillibit on topic Re:Installation Error
You seem to have problems with your Joomla installation. If you have root access, just disable FTP mode and chown all files to Apache user. Look here for more information : help.ubuntu.com/community/Joomla#Configure%20Access%20Rights
16 years 9 months ago #38945 by jjpedersen
Replied by jjpedersen on topic Re:Installation Error
I have also tried installing from a directory and also from a URL and I get the same error.
16 years 9 months ago #38988 by jjpedersen
Thank you xillibit,
I have FPT disabled and have go through and basically given '777' to my entire joomla site and I am still get that install error.
And just in case it was some kind of a time out error I tried installing the component from the TMP directory.
* It was not possible to copy the selected file. * JInstaller::install: Failed to copy file: *****/tmp/com_kunena_v1.5.9/CHANGELOG.php to *****/components/com_kunena/CHANGELOG.php
16 years 9 months ago #38989 by sozzled
Replied by sozzled on topic Re:Installation Error
I encountered a similar problem a while ago. I won't bore you with the details but I spent a week trying to sort out the problem. It turned out that I was having problems downloading files (like software installation kits) onto a particular local disk drive. In other words, my installation kit was corrupt and I had to start all over again.
Anyway, whether my experience may have any relevance to your situation, you might try this test: create a totally clean Joomla website; test it to make sure that it works; change nothing and install Kunena 1.5.9. The whole process should take you less than an hour. If this test is unsuccessful you should start investigating problems problem with your webhost. Does that sound like a plan?
16 years 9 months ago #38992 by jjpedersen
Sounds like a plan. This is a fresh install, like I said earlier - I was able to install Community Builder, Virtue Mart, and a couple of mods that I throw on all my sites and it worked great - its just when I try to install Kunena. Ill contact my hosting provider and see what magic they can make happen. In the mean time, if you think of anything else let me know.
Thanks!!
