Important Installation Error
- jjpedersen
I checked to see if I could install other components and was able to quickly install Community Builder and all the different mods and plgs.
I also looked at the file structure for my Joomla, and the install did copy the CHANGELOG.php to the components directory, so I'm not sure where to go from here.
Any suggestions?
You seem to have problems with your Joomla installation. If you have root access, just disable FTP mode and chown all files to Apache user. Look here for more information : help.ubuntu.com/community/Joomla#Configure%20Access%20Rights
- jjpedersen
- jjpedersen
I have FPT disabled and have go through and basically given '777' to my entire joomla site and I am still get that install error.
And just in case it was some kind of a time out error I tried installing the component from the TMP directory.
Anyway, whether my experience may have any relevance to your situation, you might try this test: create a totally clean Joomla website; test it to make sure that it works; change nothing and install Kunena 1.5.9. The whole process should take you less than an hour. If this test is unsuccessful you should start investigating problems problem with your webhost. Does that sound like a plan?
- jjpedersen
Thanks!!
