Question FireBoard 1.0.5 RC2 - need a copy so I can upgrade - HELP
16 years 10 months ago #37373 by slewis1972
HI
I am going from Joomla v1.13 to Joomla 1.5.15 and I need a copy of FireBoard 1.0.5 RC2 to install. I can then upgrade to Kunena.
Currently when I do it as the database has upgarde date, I get 2 different component folders and install fails. I though dont have a copy of FireBoard 1.0.5 RC2
Can anyone help?
I have searched google and not found a english one.
Scott
16 years 10 months ago - 16 years 10 months ago #37374 by sozzled
Better suggestion: don't even try to install Fireboard 1.0.5 RC2 on your new Joomla 1.5 website. Upgrade from Fireboard to Kunena 1.0.11 on your Joomla 1.0.13 website, then transfer the database across to the new websites, then upgrade to Kunena 1.5.8 from your K 1.0.11 version. Does that make sense to you?
The general procedure has been explained many times. You can easily search for examples of how to go about the process. Good luck B)
Last edit: 16 years 10 months ago by sozzled.
16 years 10 months ago #37386 by slewis1972
The upgrade seems fine apart from the multiple threads about css issues etc.
I cannot take the current forum down and then get fixes done in a suitable time frame.
By having the old version of fireboard, migrator already has brought the database files over and they are alot cleaner. I can then, subject to getting the older component, can get that installed, working. Once done, upgrade to the newer version and fix any issues.
I need to do it this way if I can but I do need a copy of FireBoard 1.0.5 RC2
has anyone got a copy then can email me?
Scott
16 years 10 months ago #37402 by xillibit
If you using fireboard 1.0.4 and previous you need to use com_converter.
I think i have repeated this a lof of time : www.kunena.com/forum/advsearch?q=fireboa...name=1&childforums=1
You don't need fireboard 1.0.5RC2 to upgrade to kunena. Just import the tables with phpmyadmin jos_fb_* in your new site and launch the installation of Kunena 1.5.8.
