Important 2 problems since upgrade to 1.5.8
16 years 10 months ago #36739 by IgorMM
hi i have J1.5.1.5and kunena 1.5.8
since i have upgraded to kunena 1.5.8 i have 2 problems.
1. first, upload avatar i get this error
* JFile::copy: Cannot find or read file: '/tmp/kn_wHoEwK'
* JFolder::create: Infinite loop detected
* JFTP::write: Bad response
* JFTP::delete: Bad response
* JFile::copy: Cannot find or read file: '/tmp/kn_Ukrhoi'
* JFile::copy: Cannot find or read file: '/tmp/kn_by7LlR'
before the upgrade upload avatars worked fine with no problems.
2. the second problem is as you can se in the picture. i cant click to chose the topic icon
16 years 10 months ago #36755 by xillibit
1°) -check the permissions of joommla directories in joomla! backend : help -> system info -> Directory Permissions
-disable the FTP layer in joomla! configuration panel
2°) look this : docs.kunena.com/index.php/Conflicting_plugins
16 years 10 months ago - 16 years 10 months ago #36819 by IgorMM
hi
problem no.1 fixed
problem 2 still not fixed
did what you wrote disable the FTP layer in joomla!
and still error
all of my folders are Writable
there in no diffrenc if a pu gd2 or gd1
but when i chose the third option, avatar does upload and no problem if its right dimencions 250x250, if its bigger, error shows.
JFile::copy: Cannot find or read file: '/tmp/kn_30hkWb' JFile::copy: Cannot find or read file: '/tmp/kn_3lfAfi' JFile::copy: Cannot find or read file: '/tmp/kn_04Wwzo'
Last edit: 16 years 10 months ago by IgorMM.
16 years 10 months ago #36829 by xillibit
Like Matias said here : www.kunena.com/forum/139-solved-or-prior...it=10&start=10#23503 , check that the owers/group of files/directories are correct.
16 years 10 months ago - 16 years 10 months ago #36839 by IgorMM
thx for the reply
i did as is said
and error still shows:
JFile::copy: Cannot find or read file: '/tmp/kn_Fidv5m' JFile::copy: Cannot find or read file: '/tmp/kn_xnI3ua' JFile::copy: Cannot find or read file: '/tmp/kn_nvOjVX'
my server specs:
Linux, sql 5.0.67, php 5.2.11 , Apache/2.2.10
16 years 10 months ago #36889 by xillibit
You need to change the owner of your files in your joomla! installation.
