Question 2 Problems.
16 years 10 months ago #36557 by LethalUK
2 Problems. was created by LethalUK
I'm trying to install Kunena 1.5 on the latest Joomla version. However, I seem to be running into some problems.
First, I get this:
-1 - An error has occurred.
It was not possible to copy the selected file.
Then, as it hasn't completed, if you go into the Kunena Component Configuration, I get this:
Warning: require_once(/home2/cbeclanc/public_html/www.ukgamingcommunity.co.uk/administrator/components/com_comprofiler/library/cb/cb.tables.php) [function.require-once]: failed to open stream: No such file or directory in /home2/cbeclanc/public_html/www.ukgamingcommunity.co.uk/administrator/components/com_comprofiler/plugin.foundation.php on line 39
Fatal error: require_once() [function.require]: Failed opening required '/home2/cbeclanc/public_html/www.ukgamingcommunity.co.uk/administrator/components/com_comprofiler/library/cb/cb.tables.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cbeclanc/public_html/www.ukgamingcommunity.co.uk/administrator/components/com_comprofiler/plugin.foundation.php on line 39
How can I solve it? Thanks.
16 years 10 months ago #36560 by etusha
Replied by etusha on topic Re: 2 Problems.
have u check file permission
16 years 10 months ago #36563 by LethalUK
Replied by LethalUK on topic Re: 2 Problems.
Which file permissions?
16 years 10 months ago - 16 years 10 months ago #36564 by xillibit
Replied by xillibit on topic Re:2 Problems.
check all your directory permissions if are writable in joomla! backend : help -> system info -> directory permissions
For your other problem, do you have installed cb and the required plugins ?
Last edit: 16 years 10 months ago by xillibit.
16 years 10 months ago #36565 by etusha
check your directory permissions in joomla! backend : help -> system info -> directory permissions
16 years 10 months ago #36567 by LethalUK
I'm new to this. I have installed Community Builder.
All the shown directory permissions shown writeable in Joomla Admin.
