Question 2 Problems.
I'm trying to install Kunena 1.5 on the latest Joomla version. However, I seem to be running into some problems.
First, I get this:
-1 - An error has occurred.
It was not possible to copy the selected file.
Then, as it hasn't completed, if you go into the Kunena Component Configuration, I get this:
Warning: require_once(/home2/cbeclanc/public_html/www.ukgamingcommunity.co.uk/administrator/components/com_comprofiler/library/cb/cb.tables.php) [function.require-once]: failed to open stream: No such file or directory in /home2/cbeclanc/public_html/www.ukgamingcommunity.co.uk/administrator/components/com_comprofiler/plugin.foundation.php on line 39
Fatal error: require_once() [function.require]: Failed opening required '/home2/cbeclanc/public_html/www.ukgamingcommunity.co.uk/administrator/components/com_comprofiler/library/cb/cb.tables.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home2/cbeclanc/public_html/www.ukgamingcommunity.co.uk/administrator/components/com_comprofiler/plugin.foundation.php on line 39
How can I solve it? Thanks.
check all your directory permissions if are writable in joomla! backend : help -> system info -> directory permissions
For your other problem, do you have installed cb and the required plugins ?
All the shown directory permissions shown writeable in Joomla Admin.
