Question Problem installing latest stable 1.5.8.
16 years 10 months ago #36380 by Lion32
I've been trying to install latest kunena on my joomla for several hours now.. tried everything but always fail.
No matter what I do (install from uplaoded package, isntall from directory) I am always getting the same:
The table jos_fb_version is created but nothing else... then if I check my components I find kunena there but it gives me this:
I tried unninstalling it and instaling it again and again.. deleting all tmp files and uplading and uncompress it on the server and then install it from the directory... still the same!
I have
PHP Version 5.2.11
MySQL - 5.0.22-log
enough freespace
so where's the problem?
16 years 10 months ago #36383 by Lion32
I forgot to tell I tryed with 1.5.7 too, needless to say with same result
16 years 10 months ago #36384 by xillibit
Check if you can, in your php.ini file if you are these values, the joomla! is a bit slow :
php max_execution_time = 120
php memory_limit = 64M
What are the tables in your database begining by jos_fb_* ?
16 years 10 months ago #36391 by Lion32
sorry, cannot check php.ini (shared hosting)
but phpinfo shows me:
memory_limit 200M
post_max_size 50M
max_input_time 600
max_execution_time 600
so I don't think the problem is in php settings
the jos_fb is only version ... no other tables and it's empty
so my guess is something gets wrong populating the DB (this table)
and obviously I cleaned the db too when I tried reinstalling kunena
16 years 10 months ago #36397 by xillibit
Do you do a clean install of kunena ? Check with this query, if the kunena installer a populate the item in jos_components, if you have a result it's good :
SELECT * FROM `jos_components` WHERE name='Kunena Forum'
16 years 10 months ago #36400 by Lion32
obviously now I do... but when trying clean installing it I remove kunena from the components
