Question Problem installing latest stable 1.5.8.
I've been trying to install latest kunena on my joomla for several hours now.. tried everything but always fail.
No matter what I do (install from uplaoded package, isntall from directory) I am always getting the same:
The table jos_fb_version is created but nothing else... then if I check my components I find kunena there but it gives me this:
I tried unninstalling it and instaling it again and again.. deleting all tmp files and uplading and uncompress it on the server and then install it from the directory... still the same!
I have
PHP Version 5.2.11
MySQL - 5.0.22-log
enough freespace
so where's the problem?
Check if you can, in your php.ini file if you are these values, the joomla! is a bit slow :
php max_execution_time = 120
php memory_limit = 64M
What are the tables in your database begining by jos_fb_* ?
but phpinfo shows me:
memory_limit 200M
post_max_size 50M
max_input_time 600
max_execution_time 600
so I don't think the problem is in php settings
the jos_fb is only version ... no other tables and it's empty
so my guess is something gets wrong populating the DB (this table)
and obviously I cleaned the db too when I tried reinstalling kunena
