Question 0 post counts 1.5.8
ALTER TABLE `jos_fb_announcement` DROP INDEX ( `id` ) ;
Is that right ?
If you want to delete the INDEX you use this syntax:
Thanks!
When I run
ALTER TABLE `jos_fb_announcement` DROP PRIMARY KEY (`id`);
I get an error, is the above correct ?
The error is,
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(`id`)' at line 1
SQL is version 5.0.58
Appreciate the help as I really need to get my site back up and running !
I ran that and get,
#1075 - Incorrect table definition; there can be only one auto column and it must be defined as a key
Thanks.
