Question Undefined variable: fbupgrade
17 years 1 day ago #33492 by borsolya
I wanna install Kunena to Fireboard 1.0.4. I try this: joomla-how-to.net/Components/upgradingmi...-fireboard-to-kunena
But I got error when I do the last step (install Kunena):
Notice: Undefined variable: fbupgrade in /data/domains/xxxx/administrator/components/com_kunena/lib/fx.upgrade.class.php on line 186
Fatal error: Call to a member function createVersionTable() on a non-object in /data/domains/xxxx/administrator/components/com_kunena/lib/fx.upgrade.class.php on line 186
Please help me! What may I do?
17 years 17 hours ago #33517 by xillibit
Do you have upgraded to fireboard 1.0.5RC2 ?
What kunena version do you want install ?
17 years 6 hours ago #33537 by borsolya
Yes, I use com_fbconverter_v1.0.5 component. It prepares the database tables to work with newer versions of Fireboard. I found it in the 'Upgrading/Migrating Fireboard to Kunena' tutorial ( joomla-how-to.net/Components/upgradingmi...-fireboard-to-kunena ).
I want to install Kunena1.5.7.
17 years 2 hours ago #33547 by xillibit
Try to install kunena 1.5.6 and then upgrade to kunena 1.5.7 because i think there is a bug into kunena 1.5.7.
16 years 11 months ago #33614 by Matias
Yes, I've already fixed this bug. This bug affects only if you are trying to upgrade FB 1.0.4 or older.
