Question Kunena 1.5.7 Problem
17 years 3 days ago - 17 years 3 days ago #33402 by philr68
Kunena 1.5.7 Problem was created by philr68
I am running J1.5.9
I built the site in a sub domain and Kunena installed an worked properly.
When we transferred thesite to the main domain there was an error when trying to load the site:
Parse error: syntax error, unexpected T_CLASS in /www/ourbulgarianworld.com/www/root/components/com_kunena/lib/kunena.config.class.php on line 65
I deleted com_kunena directories form /components and /administrator components and the fbfiles directory from /images.
I also removed the tables from the database.
The site then loaded.
I then tried to install the component again and nothing happens. It just won't install. There is no error message on the installer.
The root directory and all directories underneath are set to 775.
Have I missed something?
Last edit: 17 years 3 days ago by philr68.
17 years 3 days ago - 17 years 3 days ago #33405 by etusha
Replied by etusha on topic Re: Kunena 1.5.7 Problem
check php mysql version
Last edit: 17 years 3 days ago by etusha.
16 years 11 months ago #33665 by Matias
Replied by Matias on topic Re: Kunena 1.5.7 Problem
This parse error should not happen (the code is ok).
I see two possibilities: bug in your PHP version or you have APC/eAccelerator/XCache/Zend which is somehow breaking the code.
Did you try it again and does it work now?
Removing files and DB leads to clean install, which should work if it worked on subdomain.
