Question White page on my index.php (direct access)?
17 years 1 week ago #32976 by juanmanuelsanchez
hi all ! I installed kunena on joomla using the plugin manager and everything seems to be ok. The problem is that when I try to load the index page directly I get a white page.
So for exmaple if I try ww.mydomain.com/kunena it dosent work.
Although if I try using the menu link I configured at joomla I can see the page without problems.
WHat could be causing this behaviour? Or how can I access the forum directly.
Thanks a lot !
17 years 1 week ago #33087 by xillibit
What is the url for the menu link for kunena ?
Why you don't use this link ?
17 years 1 week ago #33094 by juanmanuelsanchez
the link in the menu is :
joomla.centromedex.com/index.php?option=com_kunena&Itemid=66
but I cant use that because the way its showing in my webpage.
So the only way to do that is to direct link the forum wich link would be:
www.centromedex.com/kunena
But all I get is a white page.
Thanks for the help.
17 years 1 week ago #33178 by Matias
Please look at Apache error log or let PHP to show errors in a page by setting:
display_errors = On in php.ini or .htaccess in your Joomla root directory.
17 years 1 week ago #33204 by juanmanuelsanchez
wait I think I made a mistake or Im confussed. wich should be the index link to the forum if I install it using joomla plugin manager?
Thanks!
17 years 1 week ago - 17 years 1 week ago #33206 by Matias
You can name it what you want, if you turn on SEF in Joomla backend. Basically it's the name of your menu item. In this case it's most likely joomla.centromedex.com/foros .
Please look at Joomla documentation how to do it.
Last edit: 17 years 1 week ago by Matias.
