Question category recount problem
I tried to use the "recount category stats" options, but it gave me
Fatal error: Maximum execution time of 60 seconds exceeded
i'm using joomla 1.5.9, kunena 1.5.0a.
What and where can I solve it?
How to upgrade my kunena 1.5.0a to 1.5.6?
If I try to install com_kunena_v1.5.6_stable_b1806_2009-10-02.zip I´ll get answer:
* JFolder::create: Failed to create a folder
* Warning! Failed to move file.
Upgrade should work just like that: just install new version.
You seem to have permission problems in your directories.
Change owner of the files to yourself or give everyone permission to write all files and directories in (remember to change also dirs itself):
components/com_kunena
administrator/components/com_kunena
images/fbfiles
Read this docs : docs.joomla.org/Special:Search?search=permissions&go=Go , docs.joomla.org/What_are_the_recommended...ctory_permissions%3F and docs.joomla.org/How_do_you_recursively_a...ctory_permissions%3F
images/fbfiles
I changed all dirs and files at
images/fbfiles
to 755 permission, but still no luck to upgrade Kunena.
What else can I do?
Look that you have saved your ftp user / password to Joomla backend (if you're using FTP mode). It may also cause JFile/JFolder to fail.
