Important Plugin Problem
- AdvancedWebSolutions
Community Builder Profile integration only works if the forum integration plugin has been enabled in Community Builder. Saving the Kunena configuration will disable integration and hide this warning.
The solutions is to go to Components > Community Builder > Plugin management and enable "Forum integration."
The problem is I do not have a plugin called Forum Integration so I cannot enable this to solve the issue.
