Question php settings for installation
17 years 1 month ago #30873 by icekake
Hi
I am new in this forum and to install fireboard in general, but liked what I read about Kunena, and decided to give it a try.
Now in required php settings on server, I see that mine are not quite like this,
php max_execution_time >= 120
php memory_limit >= 64M
safe_mode = off
but the thing is, I cant find the php.ini file on my server. It is not under .../etc/php.ini, but I found one in root of public_html, which does not give me any option to edit this.
I just wanted to know if anyone new where else to look?
The server is Linux,
Thanks,
Looking forward to install and use Kunena
17 years 1 month ago #30880 by xillibit
what linux distribution do you use ?
17 years 1 month ago #30882 by icekake
Thanks,
Sorry, I am not english, and am not sure what you mean, but host is Lunarpages, and all required settings are ok, like apache, php 5.2 and mysql 5.0
I have my server open, but I found no information like the one you ask for, please advice?
17 years 1 month ago #30883 by xillibit
Like it said on the forums of your hoster, the php.ini is in : /home/ACCOUNTNAME/public_html
17 years 1 month ago #30885 by icekake
Thanks again,
Yes, this file I found, but when I open it to edit, or change the settings, I don't see theese options, only some Zend options..
but in joomla backend I see that I don't have the right php settings
17 years 1 month ago #31311 by NetMind
Hi Icekake,
if your hoster says that your php.ini is in the home folder and it is without the required options, try to add them to this file. Could work.
Greetings,
Guido
