Question Forum is currently offline for maintenance..
17 years 2 months ago - 17 years 2 months ago #29566 by lendrin
I've installed Konena 1.5.5 and get the message:
"Internal Server Error The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, [email protected] and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error
log.",
but in the overview of "Extention" and reg.card "Components" it was marked as enabled. but if I started by Mainmenue as normel user there come the message:
"The Forum is currently offline for maintenance.
Check back soon!"
If I login as Admin, I can see the Forum, but the grafic ist disturbed and the PHP-Errormessage occured:
"Fatal error: Unable to load category list.\nDB function reports no errors in /mnt/web8/33/72/520372/htdocs/j1/components/com_kunena/lib/kunena.debug.php on line 58"
Can somebody help me?
thanks!
Lendrin
Last edit: 17 years 2 months ago by lendrin. Reason: completed the story
17 years 1 month ago #30240 by Matias
Your installation has failed on server timeout so as safety measure Kunena has locked up itself (to prevent data corruption).
You should go to phpmyadmin and delete manually all jos_fb_* tables.
You should read these:
docs.kunena.com/index.php/Installation_Issues
docs.kunena.com/index.php/Downgrading_Kunena (well, it works also if you reinstall)
