Question Need Help with Upgrade of K 1.08 to K 1.5.5
16 years 7 months ago #29465 by freedomcoach
I was successful in doing the upgrade to the latest version of Kunena but now my menu item that links to kunena forum generates the following error message:
Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 491520 bytes) in /home/breakti2/public_html/administrator/components/com_acajoom/language/english.php on line 435
I have no idea as to why this would have anything to do with ACAJoom. Anyways, I can tell on the admin back end that my forum is all in tact, just the menu item isn't working.
I vaguely recall seeing something adjustment required on this after upgrading but now I can't find it.
Please help! I need to get my board back up!
Sincerely,
Howard
16 years 7 months ago #30254 by Matias
You may have modules in your page that will take a lot of memory. Try if disabling modules help and enable debug mode in Joomla. If you do that, you will see how much memory is being used (well, if you do not run out of memory).
Usually 32M of memory is enough for Joomla and Kunena, but in some cases where you have a lot of modules and plugins, it may not be enough. Try adding php memory to 64M.
Time to create page: 0.237 seconds
