Question Profile integration Issue
17 years 2 months ago - 17 years 2 months ago #28582 by Brigog
* Problems detected in Community Builder integration: * Community Builder Profile integration only works if Community Builder User profile has been published. * Saving the Kunena configuration will disable integration and hide this warning.
Before you jump at me to read the resources...I've followed the steps outline in This Link and I get to a problem when I reach the "Profile Settings". When I pick "Community Builder" from the drop down and hit save. It tells me:
* Configuration saved. Notice * Problems detected in Community Builder integration: * Community Builder Profile integration only works if Community Builder User profile has been published. * Saving the Kunena configuration will disable integration and hide this warning.
Now for some reason it says "* Configuration saved." and everything else I changed on that page does save except "Profile Settings"...For some reason it keeps reverting back to Kunena.
I would be more then willing to let and admin log into the back end of my site to investigate it or if there is an easy fix please let me know.
Last edit: 17 years 2 months ago by Brigog.
  • cXc
  • cXc's Avatar
  • New Member
  • New Member
17 years 2 months ago - 17 years 2 months ago #28583 by cXc
Replied by cXc on topic Re: Profile integration Issue
You need to create a menu link for community builder profiles. If you go to create a new menu in Joomla and select Community Builder you will see the (mandatory) next to the item you need to use as the menu type. This is discussed in the CB readme file ...
Does anyone read the readme files anymore? o.O <- It really is twitching its just moving too fast for you to see :P
~cXc~
Last edit: 17 years 2 months ago by cXc.
17 years 2 months ago #28586 by Brigog
Bah, I skipped right over that step. Problem solved!
Thanks bud
