Question [SOLVED] Migration from 1.0.10 to 1.5.5, messages disappears
16 years 8 months ago - 16 years 8 months ago #27199
by rho
[SOLVED] Migration from 1.0.10 to 1.5.5, messages disappears was created by rho
Hi!!
I've upgraded from Kunena 1.0.10 to 1.5.5 and the first message of each post has disappeared.
You can see this at: tierras-ludicas.com/index.php/foro
I hope you can help me.
Thanks,
rho.
Thanks,
rho.
Last edit: 16 years 8 months ago by rho.
16 years 8 months ago #27208
by xillibit
Replied by xillibit on topic Re:Migration from 1.0.10 to 1.5.5, messages disappears
I never seen a problem like this before, it's very strange.
Do you have tried to upgrade to Kunena 1.0.11 and then to 1.5.5 ?
16 years 8 months ago #27210
by rho
Replied by rho on topic Re:Migration from 1.0.10 to 1.5.5, messages disappears
No, I upgraded from 1.0.10. Do you think it will works if I downgrade to 1.0.11 and then upgrade to 1.5.5?
16 years 8 months ago #27489
by Matias
Replied by Matias on topic Re:Migration from 1.0.10 to 1.5.5, messages disappears
I can see the first posts. So can I assume that the issue has been fixed?
16 years 8 months ago #27509
by rho
Yes! It's solved, it was a template problem.
I configured default_ex template and work fine, now I'm looking for a nice 1.5.5 compatible template.
Thanks,
rho.
Thanks,
rho.
- wmibge
16 years 8 months ago #27629
by wmibge
Replied by wmibge on topic Re: [SOLVED] Migration from 1.0.10 to 1.5.5, messages disappears
You know what is the most dangerous thing? Adjust my GPS volume or scale when driving. Last time when I tried to do that, I almost had a car accident…but I found something. It’s ZorroGPS. It can adjust volume or map scale according to my driving speed by itself. I installed on my car and I’m surely away from accident.
