Question Problems with installation
17 years 3 months ago #26364 by maajka
After completion of the installation componenete Kunena, when I click on the administration of this component appears to me this
Parse error: syntax error, unexpected T_CLASS in / home / korajska / public_html / components / com_kunena / lib / kunena.config.class.php on line 65
Lli me that some of you can help, that tells me what is the error?
Thanks in advance
17 years 3 months ago #26369 by sozzled
The last time I saw this symptom was with K 1.5.2b. I haven't seen a proper solution and it looks to be webhost-related. Someone suggested forcing PHP5 by adding the following line to your .htaccess file:
SetEnv PHP_VER 5
You could try that. :dry:
17 years 3 months ago #26405 by maajka
So which solution you suggest?
17 years 3 months ago #26429 by xillibit
You may try to re-uplo ad the file / home / korajska / public_html / components / com_kunena / lib / kunena.config.class.php , because it may have a problem during the ftp transfert.
