Question SMF to Kunena
17 years 4 months ago #25068
by NenadSoko
SMF to Kunena was created by NenadSoko
Kunena is the best forum for Joomla, but I use SMF 1.1.10 and I wish migrate to Kunena 1.0.11.
Does have any script for migration, or manuel.
17 years 4 months ago #25073
by xillibit
Replied by xillibit on topic Re:SMF to Kunena
Actually there is no converter to Kunena, but it exists a converter to fireboard, so you need to use fireboard and then upgrade to Kunena.
www.kunena.com/forum/101-solved--install...70-smf-to-kunea#2670
www.kunena.com/forum/101-solved--install...-simple-machines-for
joomservices.com/support/28-using-smf-to...-converter-component
17 years 3 months ago - 17 years 3 months ago #25511
by Baldcat
Replied by Baldcat on topic Re:SMF to Kunena
We are in the process at the moment, of using SMF2FB to convert SMF2 to Kunena 1.5.4
We have run into a few problems that other users hadn't as I think our forum were quite larger...
We have roughly 220,000 posts over 56 sections, 6 categories and around 5200 users.
The users aren't coming across which we have to fix, but for now you are able to sync using JFusion.. A little dirty but it works.
First successfull run through didn't deliver attached files and embeded images and the such.. How has everybody else found this ?
Last edit: 17 years 3 months ago by Baldcat.
17 years 3 months ago #25512
by irradiate
Replied by irradiate on topic Re:SMF to Kunena
I used the same convertor and it did the trick. Had 40000 posts and 1500 users.
With the users, because I was originally using the Joomlahacks bridge, so my smf users were also in the Joomla user database, so I migrated the Joomla users from 1.0 to 1.5 so my users could use the same password.
