Question installation failure in joomla 1.0.15
16 years 9 months ago #25026 by chip
downloaded the latest version for the 1.0.15 joomla and it fails during installation -
Upload component - Upload Failed
Extract Error
[ Continue ... ]
Upload component - Failed
Installation file not found:
[ Continue ... ]
16 years 9 months ago #25027 by sozzled
The version you should use for Joomla 1.0.15 is Kunena 1.0.11. Is this the version you downloaded?
16 years 9 months ago - 16 years 9 months ago #25031 by chip
com_kunena_v1.0.11_stable_b1354_2009-07-10.tar
is the one I downloaded and am trying to install.
EDIT:
okay, so I just downloaded and installed the .zip version of the same file and it almost installs, now I get this error -
I N S T A L L : F A I L E D - Minimum Version Requirements not satisfied
php version: 4.3.11 (Required >= 4.3.9)
mysql version: 4.0.27-max-log (Required > 4.1.19)
which is something I have no control over since my site is hosted on a server that is not my own. Then below that part I see this part -
Thank you for using Kunena!
Kunena Forum Component for Joomla! © by www.Kunena.com . All rights reserved.
Upload component - Success
Kunena
Kunena Forum
I see Kunena listed in the Components menu but when I click on it I get a page that says it is not installed. So apparently it is not installed yet it is installed enough to have a menu option and a page explaing that it is not installed.
Guess I'll have to try a different forum extension.
Last edit: 16 years 9 months ago by chip.
16 years 9 months ago #25035 by sozzled
... or a different hosting service ... or ask your host when they intend to upgrade MySQL. ;)
Time to create page: 0.304 seconds
