Question Installation error
17 years 4 months ago #24538 by nraja
Installation error was created by nraja
I tried to install the latest kunena1.5.4 to my site, but it gives the following error.
* It was not possible to copy the selected file.
* JInstaller::install: Failed to copy file: /home/mgstnet/public_html/tmp/install_4a65a2700eb10/template/default/listcat.php to /components/com_kunena/template/default/listcat.php
Install Component Error.
Can anyone help me out of this?
17 years 4 months ago #24540 by xillibit
Replied by xillibit on topic Re:Installation error
You have a problem with permissions rights :
Try checking your permissions:
Help -> System Info -> Directory Permissions tab
Check that they are all writeable.
And set the recommanded permissions : docs.joomla.org/What_are_the_recommended...ctory_permissions%3F
17 years 4 months ago #24544 by nraja
Replied by nraja on topic Re:Installation error
Thanks for your help, but i have checked with the permissions and it is writable
17 years 4 months ago #24547 by Lintzy
Replied by Lintzy on topic Re:Installation error
Please try to install it again from a folder on your server
www.kunena.com/forum/135-solved-installa...l-install-help#20587
