Question NewBie - Please help
17 years 4 months ago #23370 by badaddy
NewBie - Please help was created by badaddy
I keep getting the following error message when trying to view forum on my web page.... PLEASE HELP!!! Thanks
Warning: require_once(C:\xampp\htdocs\Joomla\components/com_mypms/class.mypms.php) [function.require-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\Joomla\components\com_kunena\kunena.php on line 189
Fatal error: require_once() [function.require]: Failed opening required 'C:\xampp\htdocs\Joomla\components/com_mypms/class.mypms.php' (include_path='.;C:\xampp\php\pear\') in C:\xampp\htdocs\Joomla\components\com_kunena\kunena.php on line 189
17 years 4 months ago #23371 by fxstein
Replied by fxstein on topic Re:NewBie - Please help
You have enabled integration with a 3rd party PM system (I believe Clexus) without having it installed on your system.
Go to the Kunena back-end and change the config to reflect No integration for PM and change avatar integration to Kunena.
That should do the trick.
Hope this helps!
fxstein
17 years 4 months ago #23374 by badaddy
Replied by badaddy on topic Re:NewBie - Please help
Hey Never mind I found the problem and Fixed it! Thanks Tho' BaDaddy ;)
17 years 4 months ago #23375 by badaddy
Thanks for your help!!!
