Question Installation problems
17 years 4 months ago #22890 by sarahw
Installation problems was created by sarahw
I started a thread a month ago about a problem I was having with installing the forum (I've been busy and not able to work on this).
www.kunena.com/forum/101-solved--install...3-installation-fails
I've just tried that leatest version and still get the same errors.
Warning: Could not load latest Version record.\nDB function failed with error number 1146 Table 'xxx.jos_fb_version' doesn't exist SQL=SELECT `version`, `versiondate`, `installdate`, `build`, `versionname` FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 1; SQL = SELECT `version`, `versiondate`, `installdate`, `build`, `versionname` FROM `jos_fb_version` ORDER BY `id` DESC LIMIT 1; in /home/xxx/public_html/components/com_kunena/lib/kunena.debug.php on line 71 Fatal error: Maximum execution time of 300 seconds exceeded in /home/xxx/public_html/components/com_kunena/lib/kunena.version.php on line 86
17 years 4 months ago #23034 by Matias
Replied by Matias on topic Re: Installation problems
You need to remove all jos_fb_ tables manually and then try to install again.
17 years 4 months ago #23258 by sarahw
Replied by sarahw on topic Re:Installation problems
Thankyou very much. I tried that with the last version I had, but not since I downloaded the lastest version.
Everything works as it should.
