What would be the best way to migrate the data? Hmmm .... tricky question. It depends on how "culturally significant" you consider the old data is. On the one hand it might be better to leave the old data (and website) where it is as an archive and abandon it; lock the discussions so that no new posts can be made and leave it there as a something people can look back on with fond memories. Perhaps.
The request you've made, transferring the data across, is more involved. In principle this is what I would suggest:
- On new new website, install the same version of Fireboard that you have operating on your old website.
- Export the SQL jos_fb_* tables from your old website to the new website
- Depending on what version of Fireboard you had installed, you will find information on what you need to do to convert and upgrade it to Kunena by browsing through the
Archive Fireboard
category. For example, read
Best way to upgrade from Fireboard 1.0.4
or
Upgrade Fireboard to Latest Kunena Version
- Install Kunena, uninstall Fireboard, review and create menu items as required.
What would be better than me guessing the "best way" would be for someone else to provide a comprehensive step-by-step guide to upgrading from any version of
Fireboard.
To moderators: please move this discussion to Kunena 1.0.6 – 1.0.9 and Fireboard » Installation, Upgrade and Migration category.
