Important Activation problem "Seo Friendly URLs" with Kunene 1.5.3
17 years 4 months ago - 17 years 4 months ago #22518 by domenicocg
Since updating to joomla from 1.5.10 to 1.5.11 and Kunene 1.09 1.5.3 due disable "Seo Friendly URL" because when I go to the forum cliccado different thread instead of opening the thread ritona to pagian main forum. Also found another problem when I went out I was a login error on the home page at the following file in line 47 of file kunena.category.class.php:
original
$ cat = $ kunena_db-> loadObject ();
replaced
$ kunena_db-> loadObject ($ cat);
Now the second problem but not even the first ce. Thank you
by Domenico
P.s.: I have now updated joomla 1.5.12.
Last edit: 17 years 4 months ago by domenicocg.
17 years 4 months ago #23029 by Matias
SEO: what is the wrong url you are getting and what should it be?
$ kunena_db-> loadObject ($ cat); is legacy code and does not work without legacy plugin. Do you have Discussbot enabled? It is probably the cause of this problem and needs to be upgraded.
17 years 4 months ago #23133 by domenicocg
Thank you for having responded Matias.
The Discussbot and active as to connect the news to the home page, that fact does not change by more than one error. I have not found a newer version currently use kdiscussbot_1.0.8g.
With regard Seo practically does not exit error when click on a thread is reloaded the home page of the forum. A problem not just all links indexed after activating seo does not work leads to the home page instead of wing thread, with the first version of Kunene 1:09 va works correctly.
I apologize for my English not perfect.
hello by Domenico
17 years 4 months ago #23215 by Matias
I believe that there's already version of Discussbot which works together with K1.5, but in legacy mode. Anyone wanting to point the link to us?
Can you copy some of the URL's to me? Are you using Joomla! internal SEF or some external SEF application? Some URLs have been changed between K1.0 and K1.5 and because of that a new version of sh404sef/artiosef etc plugins made for K1.5 is needed to get SEF to work again.
If there are issues with Joomla SEF, I'd like to hear more. If it's broken, just delete or rename components/com_kunena/router.php until we get this issue solved.
17 years 4 months ago - 17 years 4 months ago #23677 by domenicocg
Thank you for your availability. Give me the link to download the new version Discussbot new.
I started with the site jommla 1.5.10, the board initially Utilization Kunene 1.09. I use "Seo Friendly URL" internal joomla, As far as those links are all referring to the internal forum. Show you where to turn "Seo Friendly URL" but then users can not post.
I am not using sh404sef/artiosef etc.
Perhaps these plugins are better than internal joomla what do you recommend?
I try to verify what I have suggested.
hello by Domenico
Ps: forgot to say that other plugin or hack to use. The only plugin I use to Kunene Discussbot over and hack to hide the images to non logati and a plugin for jommlamap for the site map. Link al mio sito: Web
17 years 4 months ago #23683 by domenicocg
Renaming the file that I pointed to the "components / com_kunena / router.php" and returned to work with "Seo Friendly URL" internal joomla. Thanks much, there should be other problems you do know.
Hello by Doemnico
